Altair RISE
Nominate Yourself Now!
Check if an assembly/set is already available in a model
User: "Altair Forum User"
Updated by Altair Forum User
Hello guys,
I am new here and have less experience in scripting. I hope you can help me.  image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
My problem is the following one. I would like to check if an assembly and a set are already available in a model. I want do it by the assembly/set name.
For example, I want to to check if the assembly with the name xx is already available. When no, a new assembly is created. When yes, nothing is done.
Which command lines I have to use doing it? Thanks.
1 - 2 of 21
    OP
    Try this code:
    set assyName 'Toto';
    if { [hm_entityinfo exist assems $assyName -byname] == 1 } {
    puts 'Assy $assyName exists!'
    } else {
    puts 'Assy $assyName not found!'
    Just change 'assems' to 'sets' for checking overs Sets.
    HTH,
    OP
    That helps. Thanks.  image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
