I just getting started with FEKO and I need to add some real conductors to my model. Using the default solver, I understand that I need to set the relevant volumes to free space and corresponding faces to the desired conductor. However, I am a little confused on how to go about the 'thickness' setting. If I am dealing with a thick conductor, my understanding is that I simply pick a value that is greater than skin depth for the metal and the simulation frequency. Is this correct?
Also, in several of my simulations, the thickness of the metal in the model is actually less than skin depth. In order to model these realistically, what thickness do I need to set for the face material? Should I use the actual thickness of the metal for both the top and bottom faces? Half the real thickness for the top and bottom faces? Or the full thickness for the top face and no material set for the bottom face?
Any insight would be greatly appreciated. Thanks!
