Sir,
If I make use (I havn't) of a bolt connector, is it deformable? I mean what about its material properties?
Hi Soumitra,
depends on what type of bolt you are using.
If you are using a rigid bolt (RBE2) is not deformable. Using beam/bar type of bolt is deformable.
