Hey all,
I am trying to create several sections automatically with a tcl script. I have organized all of my parts into a Part Set, which I would likey to use as the basis for the section. The concern that I have is that the only way I can get this to work is through the GUI which enacts the following command:
*setvalue crosssections id=6 VisualizationPart_ID={sets 3}
The remainder of the section definition works well as follows:
*setvalue crosssections id=8 name=boltk geometrytype=3 basenode={0 10 152.525} normal={0 0 1} Radius=1 PartSet_ID=1
The difficulty in using 'VisualizationPart_ID' is that the given ID (sets 3 in this case) refers to the third set in the panel that pops up (also the thid set in the Sets Tree). I wont necessarily know how many sets are pre-existing in a given model, and therefore I need a means to pick the actual Set ID, which I can define myself previously in the script.
Has anyone had this issue before?
ANy workaround?
http://www.altairhyperworks.com/hwhelp/Altair/hw14.0/help/hwd/hwdref.htm?data_names-crosssections.htm
