what is the solution to update a mesh? I would like to reduce the element size.
Thank you
Use element under automesh option (remesh)Change element size and click on mesh.PFA screenshot for same.
Hi, what is the solution to update a mesh? I would like to reduce the element size. Thank you
Or enter panel 2D>Split>Plate elements with option 'Split all sides'
it will reduce mesh size by a half
