Hi to everybody,
i would like to perform a fatigue analysis using this method:
-run the dynamic analysis in Motionsolve in order to extract the load spectrum
-run the fatigue analysis in Optistruct using that load spectrum
the problem is that the dynamic analysis needs 150000 seconds, and this means an enormous amount of time in Motion solve,it's almost impossible. So is there any other way i can perform this type of analysis?
Thank you.
