Hi All,
I cann't see the Zoff on my property panel. I need to offsett the property since the elements are not created in the mid surface.
Sorry, guys
i got my answer. it is under the card edit.
Hi Ray,
if you use Optistruct profile, you can set zoff in pshell card
nastran profile doesn't have
if i set zoff in pshell while i am in optistruct profile. will this work if i am running the model through nastran. my company does not allow optistruct?
I don't think it will run. os has some features different from nastran
