I've made a simple dynamic analysis of two parts in relative motion. Now I would like to analyze stress in most critical regions. Which is the best way to procede?
Thanks!
Hi @Ferrari248F1AQ
There are two ways
1) You can replace rigid bodies with flexible bodies and run analysis in MotionSolve
2) Get the load data from MotionSolve using load export module and use the same for analysis using OptiStruct
There are tutorials available on help which can help you.
