Submitted by LAVA on Mon, 08/24/2015 - 15:14 Hi Can anyone tell me how to configure the ADC of 28335,I want to use 3 ADC's each having a different SOC(Start Of Conversion) Please help
Submitted by imatalon on Tue, 08/25/2015 - 14:50.
You can check Embedded>Examples>Delfino>ADC8 which uses 8 ADCs. You should then use the Embedded>Delfino>ADC Config block to set the ADCs to the desired SOC
Submitted by LAVA on Tue, 08/25/2015 - 16:49.
Hi, I've attached an image of what I get int the ADC properties The example given is F28068 and not F28335 The example also uses Blackhawk USB but I am using T1XDS100v1 USB... Please Help
Submitted by imatalon on Tue, 08/25/2015 - 20:12.
After checking the 28835 datasheet, it looks like there are 16 ADC channels but with only 2 sequencers. There can thus only be two sampling triggers for the ADC channels.
http://www.ti.com/lit/ds/symlink/tms320f28335.pdf
Boards like the 28068 don't have sequencers and can get all their channels triggered independently.
