Good day all . How I can export hm file from HyperMesh 2017 and then import it as hm file in 2014 HyperMesh ?? Thanks in advance .
You cannot directly open a latest .hm file in the previous version.
The possible workaround is export the file from 2017 as .fem (since you are using OptiStruct) and import the same in 14 version.
Hi, You cannot directly open a latest .hm file in the previous version. The possible workaround is export the file from 2017 as .fem (since you are using OptiStruct) and import the same in 14 version.
Thank you Mr. George
