I'm currently trying to get a GPS to output values with an f28069m board. The GPS is this model: https://cdn.sparkfun.com/datasheets/GPS/EM506_um.pdf. I'm currently getting values from the GPS Module through a serial connection, but it seems I need to decode it into an NMEA (http://aprs.gids.nl/nmea/) sequence, as the current values make no sense to me, however I know they are values from the GPS, because they change when the module is on VS off. Attached are the values I've been able to receive as well as the code I've been using to get those value. The only values I really need are Longitude, Latitude, and height.
Thank you,
Jake
