Hi! There is someone who knows how to export all the ray paths after the Propagation Simulation using the Dominant Path Model?
The ray paths computed in ProMan (with the ray tracing models or the dominant path model) can be exported by activating the propagation path output under the Propagation tab. Then the rays are written to a file with suffix *.str. The syntax of this ASCII *.str file is described in the ProMan user manual (if you search for ’str file’), please see the figure below. In ProMan it is also possible to display the computed rays together with the results (e.g. Rx power or pathloss). For this purpose you can use the ray buttons on the upper part of the tool bar on the right.
