Dear users,
   	I am working on the modelling of a material having the shape of a 'wire' (circular cross-section along axes x and y and longitudinal dimension along axis z).
   	the 'transversal' permeability of the wire (i.e., the permeability µt linking the circular magnetic field, created, for example, by a current running through the wire) is linked to the magnetic field along the z axis.
   	Is it possible to enter such a relation (between µt and Hz) in Flux ?
   	Thank you very much for your consideration. Best regards.
   	chickichik
   	PS: I just had an additionnal question just now: is it possible to simulate this material with the above mentionned conditions, without a 3D simulation (is it possible to link the transversal permability µt to a field Hz even if there is no 'z' axis as I am in 2D).
   	Thnak you for your help. Best regards.
   	chickichik
