I am new to Evolve and I am trying to split a solid object into 2 independent/separate solids using a plane as a splitting tool but it doesn't work. I used 'intersect tool' to split the object. The result I get is that the object is not split in 2 separate objects as I can see in the construction history. I am thinking I may need to collapse construction history in order to be able to split a solid into 2 separate parts. Prior to using Evolve I have been using SpaceClaim ( mechanical solid direct modeler) and this simple operation of splitting a solid into two separate solids using a plane as the splitting tool is a very simple and easy procedure in SpaceClaim.
Thanks,
Mark
