Connector: Realized Elements are Double Dependent
Altair Forum User
Altair Forum User
I've been trying to connect two surfaces using area connectors but I can't seem to get it to work. I always get the following error: 'Realized Elements are Double Dependent'
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.9c7d8956fb6857e527c77628f15afc4e.png
I'm trying to connect the surfaces in white to the bottom one in blue.
If I connect one of them first, the second will fail; If I connect both of them at the same time, they will both fail.
The mesh on both the top (yellow) component and on the bottom (blue) component is perfectly symmetric.
Can anyone help me please?
Thank you very much!
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited September 2018
    Try these 2 options below to reslove it.
    Select elements instead of surface and try again
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8db0a33acf70ff9477367e6d501423ee.png
    or
    Delete all existing FE entities associated with connectors and releasized. The duplicate rigid elements may cause this issue.
    If the problem still exists sent us your file through the secure file transfer link. We will check and reply
    https://ftin.india.altair.com:8443/filedrop/~Ma3TaE
  • Altair Forum User
    Altair Forum User
    Hello @Pranav Hari, thank you for your reply!
    I did just that, I selected the elements based on the corresponding geometries and it worked!
