I'm a beginner with HM and I'm working on a composite model aircraft wing. The wing skin is a carbon fiber composite sandwich with airex core (~1 mm thickness). I model the wing skin composite sandwich as a 2D surface directly with Laminates. The spare is a composite sandwich too and I meshed the core like a solid and its faces like a 2D surface. Is it correct?
I run the analysis with this configuration but there aren't connections between spar and skin.
This is the wing section.
Regards
Cristian
