I would like to mesh a half wavelength dipole, and the user manual does give some meshing guidelines on setting radius and segment length. I have set my radius to lambda/2000. I was wondering what would happen if I make the segment length smaller and smaller. Does it give me some erroneous result or the finer meshing would give me better result. Why?
On the other hand what if I make my segment length greater than 0.1*lambda? Is there an optimal tradeoff here? I would appreciate if someone can give a brief explanation here.
Thanks
