Hallo,
I am working on a Simulation of rivets. I have a Problem in the visualisation. After the first remesh I get the following visualisation (see attached). With LsPrePost everything works fine? Why?
Which HyperWorks version are you using?.
And I also suspect whether this is a graphics issue. Please paste the output of dxdiag (go to start > run > type dxdiag > enter > copy the display tab/s > send it to us)
hi,
Hyperworks 14.
attached the file.
Thanks.
I doubt whether this graphics card is supported.
Can you please share the .h3d file so that I can try the same at my end.
attached the file!
Thanks again for looking into my Problems.
I think this is solid adaptivity simulation. HyperView does not support adaptivity in solids, and it could be the reason for this visualization problem.
