How do I add pins to a case block? (or any other block for that matter)
User: "Altair Forum User"
Updated by Altair Forum User
Submitted by Joe on Thu, 10/15/2009 - 09:20
I've started testing Vissim and I have question. When using Vissim, I would like to change the number of cases supported by a case block. I see in the help file that this is possible. How do I go about doing so?
Thanks
1 - 1 of 11
    OP
    Submitted by Richd on Thu, 10/15/2009 - 09:23.
    Hi Joe, It's easy. Click the  button on the toolbar (or choose Edit > Add Connector...) and you are in add connector mode. Click anywhere on the left half (input side) of a block to add an input connector and right half to add an output connector. Likewise the  button (or choose Edit > Remove Connector...) will remove a connector. Not all blocks allow connector changing, but compounds, case, sum, mul, and, or, import, export, pulse, and pow do.
    Compounds let you insert connectors between other connectors. As your  cursor drifts over a connector, a small grey bar will appear above or below the connector indicating where the new connector would appear if you left click.
    To exit connector mode, click once on the background.
