hi team,
sub: door opening position to closing position for how much force we need.
team can you explain which solver and how to do...
Thanks,
nagarjuna
Hi Nagarjuna Gundamsetty,
I would suggest Motionsolve, which is a Multibody Dynamics solver. Please refer to the tutorial MV-2021: Simulating an Automotive Door Closure Event.
You may also find useful the presentation from 2nd European HyperWorks Technology Conference: Door slam simulation for durability analysis with Multibody Dynamics.
hi ivan, i done that tutorial but can you give me suggestions that how to give spring connections before it is slaming to close,,,we need that effort ... and can u give me some solution s to fing stiffness and damper values ????and how to calculate
please tell me how to consider door lock,weather strip loads???
