2 d meshing
Altair Forum User
Altair Forum User
one surface failed to mesh
  • Altair Forum User
    Altair Forum User
    edited November 2016
    viketh if u can say the problem still more clearly then i can see weather i have faced such and see weather i can help u out.......
  • Altair Forum User
    Altair Forum User
    Check which surface is failing to mesh. If the failed surface is small, delete and create again..easy :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    With this geometry, it's better to trim into small surfaces before meshing.
    You can't got good mesh with ONE-CLICK method :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    it's not easy to create 2D mesh with just one step, you should separate in to multiple surface and mesh it. it's easy to control quality of mesh and find the surface which causes error.
