Hi gents,
I am doind the MV-3000 and MV-3010 tutorials, and I would like to understand what they want to measure with the Sum of squared errors.
Is something I never heard of, and I dont know how important is.
As a definition: 'It is a measure of the discrepancy between the data and an estimation mode'
From the tutorial:
| - | The elements of Vector 1 contain actual data points of the toe curve from the solver run for the nominal configuration. |
| - | The elements of Vector 2 contain data points from the target curve. |
I believe that as much room I give to the suspension points to move, as closer I would get to the corner that is defined, right?
I imagine that if I set the variables as the suspension points in x,y & z, set the Roll Centre as a response and I define the objective as minimize it I could also have defined my problem.
And from then onwards I could try to fit my toe and camber curves to what I find ideal.
Woudl be that the best way of setting up the case?
Thanks in advance,
Gtn
