I'm importing a .hm file to the HyperStydy which is a composite model. But I'm not able to import variable other than Material and Moment.
Can you point out where I might be going wrong?
could you share .hm file for better understanding?Above attached png file is not available for view and download.
I did it /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> I was using PCOMPP, so thats why my design variable were not showing up, then i read and changed it to PCOMP.
Thanks.
Thanks for the update.Does your other query of no of plies as DV is still open?
Yes, I'm still trying to find a solution for that.
