Dear All,
I have a project where a draw operation is required for the 2 sheets joined withTaylor welded/TIG welding process. Can you please tell me the procedure for hyperform simulation?
please go through Hyperform videos:
https://www.google.si/search?q=hyperform&tbm=vid&ei=Bzv4W5WdGOeDrwTV0o6gBg&start=0&sa=N&ved=0ahUKEwjVvNaVh-veAhXnwYsKHVWpA2Q4ChDy0wMIXA&biw=1689&bih=845&dpr=1.1
Although TWBs is not demonstrated you can get an overview of how forming simulations are done in general.
Attached is tutorial HF-1040: Laser Weld
It might be that some guy named Taylor welded sheets, but they are more commonly known as tailor welded blanks /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
In user process u have to mention blank as Tailor Welded, shown in image below. After that u can define blanks with different thickness.
