any one tell the procedure of formation of new suspension template.
Hi Ayush,
What is your objective. Do you want to build a new suspension?
MotionView has a build in Assembly wizard which does a lot of parameterization which makes modelling of vehicles easy. If you want to use a particular suspension which is not in the wizard then we recommend to use a suspension which is close to yours and then modify it to suit.
