Hi ,
i am new to hypermesh customization, now i need to get a components names from a FE Model.How can i do that kindly guide me to solve this problem.
thanks in advance
thanks & regards
Suresh Kumar V
Hi, you can use
set CompList [hm_complist name]
or
set CompList [hm_entitylist comps name]
the first will raise error if no comp found but the second won't
I wrote this the other day to be able to click on the part and see what component it is
(It is useful for checking part numbers of bits after importing a big assembly for example)
#Select the component *createmarkpanel comps 1 'Select component:'
#Get name of component set name [hm_getmark comps 1] *clearmarkall 1 set comp_name [hm_getentityvalue comps $name name 1 -byid];
tk_messageBox -message 'Name of Component: $comp_name'
