At this moment I'm using the Student Edition. I want to do a planar near field measurement using a dipole as the probe and gather the near E-fields.. However, I'm having difficulties to come up with a correct method.
I tried to generate a near field radiation pattern of an dipole. Then requesting the (RX ANTENNA NF) with the AUT, but then I only get the received power in 1 point and there seems to be no easy way of converting or requesting this to/at multiple points on a planar measurement area. The parameter sweep doesn't work because of critical errors when merging.
What would be the best approach to my problem?
Thank you in advance for your time.
