Submitted by murthyakella on Fri, 06/15/2012 - 14:28
I have a small question using 'space vector modulation', 'phase Voltage calc32' and 'ACI Motor' blocks etc with delta (or triangle) connected motors.
Are these block designed for star connected motors alone? Or can they be used for delta motors too?
If they can be used for delta motors too, then can these blocks be used directly or should we add some extra blocks to transform from star to delta ?
Also, in ACI motor block, can one use delta parameters or should one use equivalent star paramters?
The reason for this question is because: mag(spaceVector_delta) = sqrt(3)* mag(spaceVector_star)and phase(spaceVector_delta) = 30° + phase(spaceVector_star)
Example: For IGBT switching sequence 001 (i.e. branch A and B = Bottom IGBT ON and branch C = Top IGBT ON),
For delta winding: Phase voltages (Ua, Ub, Uc) = (0, -Udc, +Udc ) ; mag(spaceVector) = (2/sqrt(3)) * Udc and phase(spaceVector) = 270°
For star winding: Phase voltages (Ua, Ub, Uc) = (-1/3 Udc, -1/3 Udc, +2/3 Udc ) ; mag(spaceVector) = (2/3) * Udc and phase(spaceVector) = 240°
Regards, Murthy
