hi
i want to project the seeds for on edge of my 2D geometry to the other for better quality meshing, how can i do that?
that wasn't very clear, i want to project the seeds from on edge to the facing edge in a 2D geometry
Use Project option.Project nodes to line.(Shift+F7 is the shortcut key)
i have already tried that but i wasn't able to make it work, i need a tool that will allow me to have the same y-coordinate for seeds on opposing edges in a 2D geometry
Could you share screenshot of your requirement?
i want the quasi vertical lines in the meshing to be fully vertical
simply change angle of mesh and remesh the same
Assume vertical is x axis. In panel project to line, select 'along vector' as x axis
after projecting, used panel 2d>ruled between 2 node list with option 'mesh w/o surf' will create vertical mesh line
