HI there,
Is it possible with Evolve 2016 to fix the camera of perspective viewport? I know it is possible to lock it using the icon on the top right of the view. But apart from just lock it, I would need to SAVE the view so a can use it again with the same model in the future even when I want to work with it unlocked.
thanx
Pil
Hi Pil,
No, it is not possible to save the camera location at the moment. The easiest solution is to use a new camera for modeling. You can add a new camera using the camera tool and lock the old camera. You can always go back to the locked camera when you want to get the correct view but use the new camera for modeling.
