How can I mesh the hollow surface mesh into a solid hex mesh keeping the same outer surface mesh please?
Thank you
See my test.
Go to 2D spline>> Create elements by selecting nodes
Go to 3D >> Solid Map>> End only>> select the new elements created and select the nodes on the circumference of the other side and click mesh /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
@Prakash Pagadala I tried your method, but I can't get solid mesh which respects the outer surface mesh (on the height). Any idea?
Hi @Q.Nguyen-Dai
Here is the result for the procedure I quoted:
Hi @Prakash Pagadala,
I don't think your result is asked by @dilen. Have a look at my screenshot.
Hi, do you have a version which is compatible with Hypermesh 13.0 please?
Thank you.
If you can't read my model, try the following FEM format.
Thanks but I'm not sure how you did it. What are the steps please?
Thanks
Hehe, I can't found 'automatic' method, so I do that 'manually':
Hi @Prakash Pagadala, I don't think your result is asked by @dilen. Have a look at my screenshot.
@Q.Nguyen-Dai thanks for pointing that. Not a fruitful method. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
