part of result
Altair Forum User
Altair Forum User
hello all!
i have a question!
how to load just part of result file?
i have a more than 31000 frames and how you can understand i can not load all result=(
what do i do?
i take first 4000 frames->derived result->step
and i have new subcase with 4000 steps (frames). but it loads so long too.
have you any idea?
thanks a lot!
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited August 2018
    hello all!
    i have a question!
    what do i do?
    have you any idea?
    thanks a lot!
    Your results file comes from which solver? Maybe your solver's archive parameter is too small?
    How about your hardware? CPU? Memory? graphic card?
  • Altair Forum User
    Altair Forum User
    edited August 2018
    Hi, @Q.Nguyen-Dai
    optistruct.
    i need large information, i have reduced my output as good as possible.
    i called only one part for stress result, but duration of simulation 60 s, and stend frequency increases to 55 Hz.
  • Q.Nguyen-Dai
    edited August 2018
    Yep, if you have a lot of steps, you need more memory to load results.
    I don't know if it's possible to load partial result into HV.
  • Altair Forum User
    Altair Forum User
    edited August 2018
    i have seached one way. but i thinkthat somebody knows another one=)
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.6958159cd76c5c0a387be589589609a1.png
  • Altair Forum User
    Altair Forum User
    edited August 2018
    in fatigue module you can read from T1 to T2.
  • Altair Forum User
    Altair Forum User
    edited August 2018
    @Mrt
    You can use HVtrans and select the time or steps you want to output and click translate... Job done :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    edited August 2018
    wow! i will try this approach!
    thanks a lot! could i separate my h3d file by this tool?
  • Altair Forum User
    Altair Forum User
    edited August 2018
    @Mrt
    Of course, yes...
    But make sure you save with different names
  • Altair Forum User
    Altair Forum User
    edited August 2018
  • Altair Forum User
    Altair Forum User
    edited August 2018
    are you using Student Edition?
  • Altair Forum User
    Altair Forum User
    edited August 2018
    no.
  • Altair Forum User
    Altair Forum User
    edited August 2018
    OK, since the limit of requests is capped to 10000, you can use the filter as shown in one of your images.
    Please try that and check if that helps
  • Altair Forum User
    Altair Forum User
    edited August 2018
    @Prakash Pagadala!
    sorry, i can open olnly hgtrans=(
    i have sent request to my it specialist.
    i am waiting now.
  • Altair Forum User
    Altair Forum User
    edited August 2018
    hgtrans?
    I think you want to trim the animation file, correct?
    Can you try with HVtrans?
  • Altair Forum User
    Altair Forum User
    edited August 2018
    i want to look results!=)
    i can not load 31000 time steps=) it's my reason for divide result file.
    is it possible?
  • Altair Forum User
    Altair Forum User
    edited August 2018
    i will try=)
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.243b5e4661a0b88f086fb61956ba4b85.png
  • Altair Forum User
    Altair Forum User
    edited August 2018
    thanks. it works!=)
