I faced `FMIConnector:-CreateArchive`. Error: when simulating Activate model with Modelica blocks.
What can I do for this?
---- detail ----
I ran 'C:\Program Files\Altair\2019\ActivateBasic2019.1\tutorial_models\Extended_Book_Models\Chapter_11_Physical_modeling\motor.scm' ,
then I found error messages as below:
Starting Simulation
Error: Error, (in FMIConnector:-GenerateCode) procedure: `FMIConnector:-GenerateCode`. Error:
procedure: `FMIConnector:-CreateArchive`. Error:
shared library (.so/.dll file) was not successfully generated. Check the errors by manually executing .bat file
( 99 )
Block(s): DC Motor /EMF FromModelica DC Motor /Inertia_1 Ground_2 DC Motor/Resistor_1 DC Motor/EMF ToModelica DC Motor/Inertia_1 FromModelica_2 FromModelica_1 DC Motor /Resistor_1 Ground_2_1 Torque_1 DC Motor/Inductor_1 VoltageSensor_1 DC Motor /Inductor_1 SpeedSensor_1 AngleSensor_1 StepVoltage_1
Model: motor
with Windows10 64bit, Activate 2019.1.
I found that, 'tools>compile' command shows almost same messages like this:
Starting Compilation
( 99 )
Model: motor
And, I created new Activate model includes modelica blocks and ran, then almost same Errors appeared.
That's a matter around C++ compilers?
I'm working with Visual Studio 2017 Express, and
> vssGetCompilerName()
ans = vc_env
seems OK.
Regards.
