I have two square beams in contact. I define master and slave surfaces and impose static friction (mu=0.3) between them with S2S discretization.
The loading is pretension through rod elements (modeling a bolt) and I use inertial relief since there are no constraints. I'm using a nonlinear quasi-static solver.
I get the following error message.
A fatal error has occurred during computations:
*** ERROR # 941 ***
NON-CONVERGENT NONLINEAR ITERATIONS FOR SUBCASE 1
Suggestions:
* Friction or STICK can cause more difficult nonlinear convergence - if feasible
try frictionless gap/contact.
* This problem has gap elements with friction or stick condition. For more
intuitive results and often better convergence, set GAPOFFS on GAPPRM card
to AUTO. (This may violate rigid body balance, especially for unsupported
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
How can I resolve this?I
attached the full error message and .out file for your reference.
Thanks,
Matt
