Hey there!
When I try to import a session file from my local destination I get an error stating that the location cannot be identified. Kindly help<?xml version="1.0" encoding="UTF-8"?>
Hi @VAMAN SHENOY
Can you check if there is a h3d file available in the same location?
it looks like HM19.h3d is either deleted or not available in the specified location.
Session file is just ASCII format. So you can open it and update your model path.
@Prakash Pagadala @Q.Nguyen-Dai Yes I failed to request the proper output format. Issue Sorted. Thank You!
