I am using FEKO to simulate a Bluetooth antenna to measure its reflection coefficient and radiated power. When setting up my model I requested Far Field to be a 3D pattern. After successfully finishing the simulation, I graphed the Far Field / radiated power, and these were my results:
(I ran two simulations. One where the antenna has no ground plane and one where the antenna does have a ground plane)
How can I interpret my results? Why it the radiated power not coming from where the wire port is located?
I have attached both models (ground plane and no ground plane) for your review.
If anyone is able to help me understand my problem, I would greatly appreciate it!
Thanks,
Yolanda Gonzalez
