I am using Hyperwork version 2017.2, but I can't see Vehicle Tools in menu bar Motion View.
Can you please help me?
Thanks for the replies!
Hi @oihk
Go to File Menu>> Load>> Preferences>> MBD- Vehicle Dynamics tool and click Load.
This should bring Vehicle tools
Hi Prakash Pagadala. Thank you so much for your support.
I want to simulate a truck running on the road from the road's file I dowloaded in the opencrg.org website, but the first obstacle I encountered was the truck and the road opposite each other. ( I used the vehicle tools to import road into the model).
Is there a way to change the direction of the truck or road?
Hope to be got your helps.
@oihk how about changing the origin point?
@Prakash Pagadala I'm sorry for replying late. If I change the original point of the road. The driver path file (.ddf) will not correct.
In case, just create another marker for road graphic only and use it to reverse the direction of the graphic
