I posted a post in Post processing tab but was requested to put in the pre processing.
Could anyone explain me the problem in the structure because of which the damage is happening?
yours sincerely,
kartik kanugo
I tried the same thing in 2017 radioss as well it is still not working. Could you tell me where in the preprocessing I have made the fault?
Kartik
I tried it by changing the property to P14_Solid
This is what i got.
Thankyou
Hello ,
thank you for your reply,
I know the setup works when we use a P14 solid element but why doesn't it work with a thick shell element formulation.
I wish to know where in thick shell formulation did i go wrong.
