I wanted to know if I can replace glue contact with a RB2 (node to node), CGAP (node to node ) or simply by doing a node equivalence between two surfaces.
Would it make a difference???
Thanks.
Hi Ashwani,
Node to node equivalency will ensure the proper connectivity between components. Whereas in contacts, it will check for potential penetration of a slave node through a master segment.
Please refer the Nastran documentation for these contact types.
We can guide you if you are solving with OptiStruct, which is the structural analysis solver of Altair. There are many tutorials and webinars available on contacts in the Help Menu of OptiStruct.
