I am trying to simulate a spiral antenna. I have simulated other antennas before and have been using the same method to get the results that I am looking for. However, with this spiral antenna I am having some difficulties.
The substrate of the antenna has a thickness of 14 um. When I construct the infinite substrate and add the thickness, it shows it as being much thicker. For reference I have put a picture of the previous antenna I was working on that has the same measurements for the substrate.
Spiral Antenna Previous Antenna
For the Frequency I have it set as Linearly Spaced Discrete Points with a start frequency of 1 GHz and an end frequency of 3 GHz. It is set to calculate a number of 100 frequencies with 20.202 MHZ increments. For the port of the spiral antenna, I have created an edge port that is slightly above the substrate (shown below).
When I tried to run the FEKO Solver I got this error message.
ERROR 36628: The triangles of a metal surface are not all located in the same medium
Does the edge port have anything to do with this message? If so, how can I fix it?
And how does the thickness of my infinite substrate effect the outcome of my results?
Thanks,
Yolanda Gonzalez
