Any command for getting the total number of entities present in components or loadsets or cards ? Like in Cards, if I have defined 2 output requests, I want the count 2.
Thanks.
Hi
with components, you can count entity by marking
*createmark entitytype 1 'by comp name' $compname
hm_marklength entitytype 1 => count
with loadsets (i am not sure what loadsets is, but if you mean 'loadcols'), do it same as components
with cards, it's a bit complex
for example card GLOBAL_OUTPUT_REQUEST, you define 2 output for ACCELERATION
you can get this number by hm_getentityvalue cards GLOBAL_OUTPUT_REQUEST \$ACCELERATION_NUM 0 -byname
with other output, you can search for relevant template-defined data name in template file (press G to know path of template file and look inside it)
