Submitted by Joe on Sat, 09/05/2009 - 01:04
For ADC, does Analog input block “f281x-Ain:0” already shift 4 bits (the generated code showed it is so), therefore, this block gives exactly what is input (analog) at the pin. Where can I find the info for the channel chart: for example Ain:0 is ADCINA0, etc. Also where can I find the chart for Analog output, e.g., Aout:0.. etc. I didn’t see the converted results are accurate. Maybe I miss something. I did read the readme instruction to put the input to analog pin and Vreflo.
Thank you for your help.
