Submitted by erasco on Tue, 03/23/2010 - 22:22
How do I go about creating a *.map file? I need a two-column look up table. I have tried Excel, wordpad and such but cannot find a 'save-as' .map option. Please help! Thanks, Eric
Submitted by Anders89 on Tue, 03/23/2010 - 22:39.
The file suffix does not matter. You can use .csv (Excel comma separated value), .txt, .dat, .map, or .foobar
Submitted by abida86 on Fri, 03/26/2010 - 23:35.
To use a map block in vissim we need map files. Can u please explain how to create a .map file?
Submitted by Richd on Sat, 03/27/2010 - 01:28.
Here, follow these steps:
Submitted by a_a on Sat, 03/27/2010 - 01:01.
If you go to in the menu: Diagram > Examples > Blocks > Nonlinear, there are a few map examples. You can edit a .map file using Notepad and save the file as .txt and then rename it as .map in Windows
Submitted by erasco on Tue, 03/30/2010 - 20:53.
Thank you for the very useful info. Problem solved.
