after i create a surface mesh I am unable to see the nodes . How do i view the nodes ?
when/how do you use Geometry-->midsurface-->Surface Pair ? How is it different from automatic midsurface ?
what are temp nodes ?
thanks in advance for your help.
Sir,
Temp Nodes are Nodes Which are used to perform further activities like project, Translate, etc....and to capture Geometry of CAD...
with thanks,
Arun.M
arunbharathi.epm@gmail.com
Both Automatic mid surface & surface pair are performing same task...but...if CAD thickness varying frequently v go for auto and surface is even go for Surface pair,
With thanks,
