I am trying to morph a mesh onto a surface using 'morph to geometry' command. Before morphing, it is important to align the mesh and geometry correctly. For this I used 'Tool>position' command. But I had to use this command several times to align the to entities correctly. Since I have to do a lot of morphing on different entities, I was wondering if there is any automatic/semi automatic way to align them appropriately before morphing? Or is there a script based method to input a 4x4 transformation matrix into Hypermesh for aligning two entities?
Thanks for your help.
Harish
