Hello all,
i need to join rib surfaces in a cast part, so that they become a t-connection with 3 surfs sharing one edge. At the Moment, the surfaces do not connect.
How can i do that quickly?
Hello
in panel surface edit, choose trim with surface and activate 'trim both' will create t-junction
