I use template function *field(real,x,14) to output X-coordonate of node.
Sometime I got '1.31096108-15' and my software claims that's not correct scientific format.
How to make output of the form 1.31096108E-15 please ?
Thanks
Maybe it is a problem, since you have ordered values of type real with a maximum width of 14. Your value has more then 14 digits, so there is a conflict.
Try to use the 'exponential' format. I can't check it so fast, it is more or less a assumtion...
Mario
Hi Mario,
'exponetial' format works well for me.
Thank you so much for your reply.
Best regards
