Hello users,
I am trying to orientate the mesh as is shown in the following picture. Which way I should follow to create an oriented mesh?
Thanks you.
Best regards
Use 2d>ruled mesh, switch option to 'mesh w/o surf'
Thanks Tinh
Hello Aaron,
You can even use the basic option Auto-mesh in 2 D panel, with the desired the element size. Also, make sure that, in the sub panel of Auto-mesh ,select the options as shown in the attached image.
But, do learn the reason for choosing those particular options.
Akshay S Patil
Hello Akshay S Patil,
I tried your way but it does not work unfortunately. Thanks by the way.
Best regards,
Aaron Klett
Please make sure that you click on set all for element type & mesh method before mesh.
