When I check result from hyperview, it failed to load in any result file. Could anyone help?
Hi Brenna liu
Change the Result math template to advanced option and try
I re-run Optistruct and goes to hyperview, I get the error below. Nothing loaded. See picture 1.
Interesting, I un-check the load results only check the Load model, I can load the model. See picture 2
Then I un-check the Load model only check the Load results, I can get result.
But I can not load them together.
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>See picture 3.
If you are using OptiStruct as the user profile, try loading the .h3D file
Hi, .h3D get the same error
Can u share the image of the graphic window and the error
Please see attached
Please another copy
Normally there is no result math operations, if you are loading model and result files only.
Do you have created result math within the expression builder? If yes, post it please.
Result math operations are saved also in the *.mvw files, including the result math template.
If you are using sessions, then you can search for Standard in mvw and replace it by Advanced.
Otherwise it will not work with sessions.
Best Regards,
Mario
Could you please try h3d file for both model and result.
Actually this is the most common way to view the analysis result from OptiStruct
Hi Brenna liu,
Please can you share your model.
Please use below FT link to share your model.
https://ftin.india.altair.com:8443/filedrop/~osKE8Q
Thank you
