The antenna is designed from air dielectric cube with PEC surface. A waveguide port is used for a excitation source. After that, I have request standard and CMA configurations. Then the simulate display the error 37583.
   	After that, I removed the standard configuration and try to simulate again. The error has been change to display error 37597.
   	Thank you for your time.
